ajustei a senha, so que agora voltou em branco
nfs_3a18938cacc84818849a1b0bc5f3c558
O provedor da prefeitura está retornando um erro não esperado.
Segue o envelope SOAP de resposta:
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="urn:index.EnviarLoteRpsSincronoEnvio" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<SOAP-ENV:Body>
<ns1:EnviarLoteRpsSincronoEnvioResponse>
<return xsi:type="xsd:string"><?xml version="1.0" encoding="UTF-8"?>
<result><![CDATA[An exception occurred while executing 'WITH dctrn_cte AS (SELECT TOP 1 n0_.ID_LOTE AS ID_LOTE_0, n0_.ID_SISTEMA AS ID_SISTEMA_1, n0_.US_CRIACAO AS US_CRIACAO_2, n0_.DT_CRIACAO AS DT_CRIACAO_3, n0_.US_ALTERACAO AS US_ALTERACAO_4, n0_.DT_ALTERACAO AS DT_ALTERACAO_5, n0_.ID_INSTITUICAO AS ID_INSTITUICAO_6, n0_.SERIE AS SERIE_7, n0_.DIA AS DIA_8, n0_.MES AS MES_9, n0_.VALOR_NOTA AS VALOR_NOTA_10, n0_.DATA_EMISSAO AS DATA_EMISSAO_11, n0_.DATA_VENCIMENTO AS DATA_VENCIMENTO_12, n0_.PERIODO AS PERIODO_13, n0_.MATR_FISCAL AS MATR_FISCAL_14, n0_.OBSERVACAO AS OBSERVACAO_15, n0_.HISTORICO AS HISTORICO_16, n0_.DESCRICAO_TIPO_SERVICO AS DESCRICAO_TIPO_SERVICO_17, n0_.HISTORICO_CANCELAMENTO AS HISTORICO_CANCELAMENTO_18, n0_.CODIGO_PRESTADOR AS CODIGO_PRESTADOR_19, n0_.CODIGO_TRIBUTO AS CODIGO_TRIBUTO_20, n0_.CODIGO_SITUACAO AS CODIGO_SITUACAO_21, n0_.FLAG_EMISSAO AS FLAG_EMISSAO_22, n0_.CODIGO_INTERNO AS CODIGO_INTERNO_23, n0_.ISS_RETIDO AS ISS_RETIDO_24, n0_.ALIQUOTA AS ALIQUOTA_25, n0_.VALOR_DEDUCOES AS VALOR_DEDUCOES_26, n0_.DESCONTOS_INCODICIONADOS AS DESCONTOS_INCODICIONADOS_27, n0_.DESCONTOS_CONDICIONADOS AS DESCONTOS_CONDICIONADOS_28, n0_.OUTRAS_DEDUCOES AS OUTRAS_DEDUCOES_29, n0_.FLAG_IMPOSTO_FEDERAL AS FLAG_IMPOSTO_FEDERAL_30, n0_.CODIGO_OBRA AS CODIGO_OBRA_31, n0_.CODIGO_ART AS CODIGO_ART_32, n0_.VALOR_ISS_RETIDO AS VALOR_ISS_RETIDO_33, n0_.COD_RECIBO_SERVICO AS COD_RECIBO_SERVICO_34, n0_.NUMERO_RS AS NUMERO_RS_35, n0_.TIPO_RS AS TIPO_RS_36, n0_.DATA_RECIBO AS DATA_RECIBO_37, n0_.DATA_CANCELAMENTO AS DATA_CANCELAMENTO_38, n0_.COMPETENCIA AS COMPETENCIA_39, n0_.INCENTIVO_FISCAL AS INCENTIVO_FISCAL_40, n0_.QTD_ITEM AS QTD_ITEM_41, n0_.CARTA_CORRECAO AS CARTA_CORRECAO_42, n0_.NUMERO_LOTE AS NUMERO_LOTE_43, n0_.PROTOCOLO AS PROTOCOLO_44, n0_.CODIGO_VERIFICACAO AS CODIGO_VERIFICACAO_45, n0_.FLAG_SUBSTITUIDA AS FLAG_SUBSTITUIDA_46, n0_.STATUS_RPS AS STATUS_RPS_47, n0_.CODIGO_CANCELAMENTO AS CODIGO_CANCELAMENTO_48, n0_.INSCRICAO_PRESTADOR AS INSCRICAO_PRESTADOR_49, n0_.INSCRICAO_TOMADOR AS INSCRICAO_TOMADOR_50, n0_.INSCRICAO_ESTADUAL_PRESTADOR AS INSCRICAO_ESTADUAL_PRESTADOR_51, n0_.ENDERECO_PRESTADOR AS ENDERECO_PRESTADOR_52, n0_.NUMERO_PRESTADOR AS NUMERO_PRESTADOR_53, n0_.COMPLEMENTO_PRESTADOR AS COMPLEMENTO_PRESTADOR_54, n0_.COD_CIDADE_IBGE_PRESTADOR AS COD_CIDADE_IBGE_PRESTADOR_55, n0_.COD_CIDADE_IBGE_TOMADOR AS COD_CIDADE_IBGE_TOMADOR_56, n0_.ENDERECO_TOMADOR AS ENDERECO_TOMADOR_57, n0_.CIDADE_TOMADOR AS CIDADE_TOMADOR_58, n0_.CPF_CNPJ_TOMADOR AS CPF_CNPJ_TOMADOR_59, n0_.BAIRRO_TOMADOR AS BAIRRO_TOMADOR_60, n0_.NUMERO_TOMADOR AS NUMERO_TOMADOR_61, n0_.COMPLEMENTO_TOMADOR AS COMPLEMENTO_TOMADOR_62, n0_.FONE_TOMADOR AS FONE_TOMADOR_63, n0_.CEP_TOMADOR AS CEP_TOMADOR_64, n0_.NOME_TOMADOR AS NOME_TOMADOR_65, n0_.UF_TOMADOR AS UF_TOMADOR_66, n0_.COD_PAIS_TOMADOR AS COD_PAIS_TOMADOR_67, n0_.COD_PAIS_PRESTADOR AS COD_PAIS_PRESTADOR_68, n0_.BAIRRO_PRESTADOR AS BAIRRO_PRESTADOR_69, n0_.CIDADE_PRESTADOR AS CIDADE_PRESTADOR_70, n0_.UF_PRESTADOR AS UF_PRESTADOR_71, n0_.CEP_PRESTADOR AS CEP_PRESTADOR_72, n0_.INSCRICAO_ESTADUAL_TOMADOR AS INSCRICAO_ESTADUAL_TOMADOR_73, n0_.FLAG_WEBSERVICE AS FLAG_WEBSERVICE_74, n0_.SITUACAO_LOTE AS SITUACAO_LOTE_75, n0_.NUMERO_NOTA AS NUMERO_NOTA_76, n0_.TIPO_NOTA AS TIPO_NOTA_77, n0_.EXERCICIO AS EXERCICIO_78, n0_.COD_ENQUADRAMENTO AS COD_ENQUADRAMENTO_79, n0_.COD_PESSOA AS COD_PESSOA_80, n0_.CODIGO_TOMADOR AS CODIGO_TOMADOR_81, n0_.COD_NATUREZA AS COD_NATUREZA_82, n0_.COD_ATIVIDADE AS COD_ATIVIDADE_83, n0_.COD_TIPO_SERVICO AS COD_TIPO_SERVICO_84 FROM NOTA_FISCAL n0_ WITH (NOLOCK) INNER JOIN CONTRIBUINTE c1_ ON n0_.COD_PESSOA = c1_.COD_PESSOA INNER JOIN PESSOA p2_ ON c1_.COD_PESSOA = p2_.COD_PESSOA LEFT JOIN PESSOA_FISICA p3_ WITH (NOLOCK) ON (p3_.ID_INSTITUICAO = p2_.ID_INSTITUICAO AND p3_.COD_PESSOA = p2_.COD_PESSOA) LEFT JOIN PESSOA_JURIDICA p4_ WITH (NOLOCK) ON (p2_.COD_PESSOA = p4_.COD_PESSOA AND p2_.ID_INSTITUICAO = p4_.ID_INSTITUICAO) WHERE n0_.NUMERO_RS = ? AND n0_.SERIE = ? AND n0_.TIPO_NOTA = ? AND n0_.EXERCICIO = ? AND p4_.CNPJ = ?) SELECT * FROM (SELECT *, ROW_NUMBER() OVER (ORDER BY (SELECT 0)) AS doctrine_rownum FROM dctrn_cte) AS doctrine_tbl WHERE doctrine_rownum <= 1 ORDER BY doctrine_rownum ASC' with params ["", "1", "1", "265", "29763858000190"]:
SQLSTATE[42000]: [Microsoft][ODBC Driver 13 for SQL Server][SQL Server]Error converting data type nvarchar to numeric.]]></result></return>
</ns1:EnviarLoteRpsSincronoEnvioResponse>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Envie uma mensagem privada com o envelope SOAP que foi enviado, onde você pode verificar que o token agora está sendo incluído no XML.
Favor encaminhá-los para o suporte da prefeitura.
ok assim que provedor me responder posto aqui .obrigado
o provedor disse (pianco -PB )
- a gente não tem suporte ao SOAP, utilizamos agora REST
Layout RPS da NFSe v003.zip (509,8,KB)
se precisar de algo a mais pego no site , obrigado
fico no aguardo, se poderem ver por favor.
Boa tarde @falecom
Ao acessar o link: https://portaldocontribuinte.publicsoft.com.br/sistemas/PortalDoContribuinte/views/ é exibido um aviso:
Prezado (a) Contribuinte,
A URL antiga do Web Service da NFS-e foi substituída, utilize a nova URL: (Link)
Esse link acima tem o botão REST Documentação API.
Para acessar, precisará fazer Login. Para obter as informações de acesso, vá ao Portal do Contribuinte, efetue login.
(Para ter acesso ao restante dessa ajuda, é preciso estar logado no Portal do Contribuinte.)
Atenciosamente,
Equipe de Suporte
Por favor, pode acessar o referido link, confirmar se a documentação é a mesma desse PDF que disponibilizou previamente e caso seja diferente, disponibilizar para nós?
Pergunto isso pois o manual que disponibilizou tem um leiaute .TXT para importação de arquivo no sistema.
Considerando que o provedor utilizava leiaute baseado na versão 2.03, isso na verdade me parece uma regressão da parte deles.
No mesmo PDF também tem um trecho que da a entender que tem uma documentação específica:
Estemanualnão contemplaasubstituiçãodoReciboProvisóriodeServiços (RPS) porNFSe (conversãoemlote)…
Uma postagem foi dividida em um novo tópico: Claim “iat” is invalid
baixei novos hoje ve se sao esse por favor
Layout-RPS-NFSe-v003-v1.3 (1).zip (763,0,KB)
mandei os dados de acesso em particular , confirmar se chegou
Bom dia.
Confirmado, dados recebidos.
Vamos avaliar as informações e reportamos assim que tivermos novidades.
eles me passaram isso
Manual Abrasf contém o passo a passo para construção do XML (anexado no comentário) e para se comunicar com nossa api via REST, a documentação contendo todos os nossos endpoints está disponível ao lado do botão “Manual Abrasf 2.0.3” e o link de comunicação para a api de nota fiscal eletrônica é (https://apinfse.publicsoft.com.br/api + sufixo) o sufixo está disponível na documentação REST como por exemplo /api/gerar-nfse-envio.
NFS-e_Manual_de_Integracao_versao_2.03_alteracoes (4) (1).zip (941,9,KB)
Boa tarde!
Essa informação me parece fazer mais sentido.
Comparando o arquivo que você disponibilizou via mensagem privada o mesmo era semelhante ao que foi disponibilizado inicialmente.
Revendo ainda o PDF, o mesmo tem data de 2020 então é mesmo um PDF antigo.
Este PDF que disponibilizou agora é o leiaute da ABRASF.(sendo honesto, ele não ajuda muito, pois o arquivo XML para esse provedor, já é montado de acordo com este leiaute.
Esta parte no entanto, ajuda bastante:
é para eu mandar qual mensagem para eles ?
quer que passe alguma outra mensagem para o provedor mandar algo?
Boa tarde.
Se possível, por favor, veja se eles podem disponibilizar o link para acessar essa documentação do print que ou se for uma collection para importar no PostMan ou software semelhante se eles podem disponibilizar o arquivo.
mas para acessar o link tem que esta autentificado voces tentaram usando o que passei de usuario e senha para acessar o paniel ? eles falram que esta no PDF como gerar o link , estando logado no cliente
mas mandei isso que vc pediu estou esperando ve o que ele vai dizer, e que li no que eles passaram eles falam que m no REST mostrando como esta no print la em cima diz que tem que esta logado
pronto eles me passaram como faz para chegar nisso
eu vou mandar no privado as chave do usuario para acessar o link
ai vai dar certo
@diego.foliene deu certo o acesso?
Boa noite, @falecom.
Ainda estamos analisando a viabilidade dessa implementação.
Retornaremos o mais breve possível, favor aguardar.
