Estou recebendo esse erro, prefeitura Mantena - MG:
Emissão:
Download:
Consulta:
o retorno completo é esse:
“id”: “nfs_3a16e8617df94b128e338887a8c2ffd2”,
“created_at”: “2024-12-16T19:59:54.858Z”,
“status”: “erro”,
“referencia”: “teste”,
“serie”: “NFSe”,
“nDPS”: “202400000000761”
“codigo”: “HTTP 403”,
“descricao”: “<html lang="en-US">Just a moment…<meta http-equiv="Content-Type" content="text/html; charset=UTF-8"><meta http-equiv="X-UA-Compatible" content="IE=Edge"><meta name="robots" content="noindex,nofollow"><meta name="viewport" content="width=device-width,initial-scale=1">*{box-sizing:border-box;margin:0;padding:0}html{line-height:1.15;-webkit-text-size-adjust:100%;color:#313131;font-family:system-ui,-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Helvetica Neue,Arial,Noto Sans,sans-serif,Apple Color Emoji,Segoe UI Emoji,Segoe UI Symbol,Noto Color Emoji}body{display:flex;flex-direction:column;height:100vh;min-height:100vh}.main-content{margin:8rem auto;max-width:60rem;padding-left:1.5rem}@media (width <= 720px){.main-content{margin-top:4rem}}.h2{font-size:1.5rem;font-weight:500;line-height:2.25rem}@media (width <= 720px){.h2{font-size:1.25rem;line-height:1.5rem}}#challenge-error-text{background-image:url(data:image/svg+xml;base64,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);background-repeat:no-repeat;background-size:contain;padding-left:34px}@media (prefers-color-scheme:dark){body{background-color:#222;color:#d9d9d9}}<meta http-equiv="refresh" content="390"><body class="no-js"><div class="main-wrapper" role="main"><div class="main-content"><div class="h2"><span id="challenge-error-text">Enable JavaScript and cookies to continue”
Olá, @comercial5.
O erro parece estar relacionado a uma falha de permissão na comunicação com a prefeitura (HTTP status code 403).
Recomendo conferir se as credenciais de acesso foram configuradas corretamente na seção Configurações de NFS-e.
Olá, estou retomando esse tema, estava ficado na implementação de NFCe e tinha deixado NFSe para depois, agora retornando o erro segue exatamente o mesmo, eu já fiz a verificação na prefeitura e está ok a empresa, inclusive eu emiti uma nota usando a api da Asaas para essa mesma empresa, então não é nada relacionado com a prefeitura, lá está ok, fiz nova implementação e transmiti notas para testar e todas aparecem esse mesmo erro 403 e escrito: Just a moment… parece que isso tem relação com proxy da cloudflare, poderia por favor tentar me dar uma ajuda mais especializada?
id de nota transmitida de exemplo:
a nota nem chega a aparecer no portal da prefeitura com erro no RPS como aconteceu com o Asaas algumas vezes até eles ajustarem o que precisava e então funcionou, parece que algo está bloqueando antes de chegar lá
O município mudou de provedor.
Favor acompanhar no seguinte tópico:
